help with alternater on 94 850 t
Old Jul 26, 2007 | 11:11 AM
240maybe's Avatar
Default help with alternater on 94 850 t
Ok the alternator is bad on my 850 and i cant seem to get the thing off. i took the pivot bolts off and everything but its not budging, anyone have a link or something to help me out with this?
thanks lots in advance!
Old Jul 26, 2007 | 12:44 PM
JPN's Avatar
JPN
Default RE: help with alternator on 94 850 t
Hi,
The alternator is held by 3 bolts, one of which is kind of hidden closer to the engine block and you have to feel it in order to get to it. Also, you may need to use a combination of shallow or long socket with short extension or a universal joint. A few things have to come off too, such as the plate that holds the serpentine belt idler pulley. Once those bolts are off, tap it with a soft-face hammer or with a steel hammer + a piece of wood (wear eye protection if you decide to take this route) or something soft. I would keep track of where everything was.
Let me know if you need further assistance. Also, posting question in vehicle-specific sections help you better.
Good luck,
JPN
Old Jul 26, 2007 | 05:50 PM
There is also a slide bushing where the long bolt goes through. You have to wobble the Alt. back and forth to get it to slide back some to pull the Alt. out.
Old Jul 29, 2007 | 11:04 PM
240maybe's Avatar
thanks for the help, i got the alternator off and the new one goes on tommorow
Old Jul 29, 2007 | 11:07 PM
JPN's Avatar
JPN
Glad to hear your success. Good luck on the installation, and make sure that the battery is fully charged before you hook up the wires to the alternator.
JPN
lydjan37
Sep 13, 2010 07:11 AM
talon0930
May 23, 2010 09:07 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
