I need A7 and B2 codes for OBD
Old Sep 20, 2007 | 09:46 PM
volvo850sdca's Avatar
Default I need A7 and B2 codes for OBD
I hope somebody can help me, I have A7 codes 1-2-2, and B2 1-2-2. What are this codes meaning?
Old Sep 21, 2007 | 11:41 AM
JPN's Avatar
JPN
Default RE: I need A7 and B2 codes for OBD
Welcome to the forum,
OBD-I socket A7 is CRZ CTRL. Code 1-2-2:
Speed Below Minimum/No Signal.
Quote from the factory manual: "Code 1-2-2 is stored when ignition is turned on. It remains until vehicle speed is greater than 22 MPH for at least 15 seconds. If code remains after a road test at speeds greater than 22 MPH, control unit is not getting speed signal."
Socket B2 is for instrument: Code 1-2-2:
Temperature Sensor/Interval Too Long.
Wait until other members reply, or buy a Haynes manual for approx $15-$17.
I hope this gets you started.
JPN
Old Sep 21, 2007 | 12:49 PM
billofdurham's Avatar
JPN,
With apologies I would point out that B2 is the cruise control and A7 is the combined instrument. The descriptions are correct but I would add that B2 1-2-2 will always show if the codes are read immediately the ignition is switched on. To do this test the vehicle should be drivenat 22mph + for at least 15 seconds and the codes read before the ignition is switched off. It seems that it was designed to confuse the DIY man.
Old Sep 21, 2007 | 11:18 PM
JPN's Avatar
JPN
Hi Bill,
Thanks for correcting me, I must've had a mid-age moment.
Or, it must have been due to the stress I get from working in Japan[:@].
Cheers,
Kanji/JPN
TBDSeattle
Sep 18, 2012 05:42 PM
phiber
Aug 27, 2008 07:36 PM
air force rascal
Apr 22, 2008 10:47 PM
Jamez2u
Oct 1, 2007 06:34 PM
justin
Mar 15, 2006 01:29 AM
