i think i ruined my ball joint
Old Apr 5, 2008 | 08:30 PM
sheriffjohn's Avatar
Default i think i ruined my ball joint
[:@]in removing my right ball joint i was forced to use a chizle and hammer to get it out and install a new drive shaft.after reassembly i found i had movement in my wheel from right to left .do you think i ruined the ball joint or screwed up some other part of the job. thanks muchly
Old Apr 5, 2008 | 09:16 PM
Default RE: i think i ruined my ball joint
If it is from right to left that should be either inner or outer tie rod.
Top to bottom play will be balljoint.
dpvovo
Feb 18, 2019 07:41 PM
mike1973
2001-2013 model year XC70
Oct 2, 2014 06:55 PM
David-Omaha
Aug 19, 2010 05:02 PM
CRC1021
Feb 23, 2010 09:03 PM
indagutter
Oct 11, 2004 07:10 PM
