Light up ABS
Old Oct 9, 2012 | 07:01 PM
Paulina Yuniarsih's Avatar
Default Light up ABS
Hello guys..i have volvo '98 s70. i have problem with my car. when i wanted switch on my key suddenly light up ABS. I dont know why cause there was not happen before. and i tried drive and suddenly light off ABS. the next day my light up ABS again. but when i drive there was not problem. i was worry cause ABS light always come in and come a way.. anyone can help me please???
hopefully guys, you can give me advise??? thanks alot...
paulina
Old Oct 9, 2012 | 08:43 PM
difflock54's Avatar
Your ABS warning light in your dash cluster should come on briefly when you first turn the ignition key to the first position and then go out. (2 or 3 seconds normally)
If it remains on after the engine starts and / or you subsequently move off then you probably have a need to check your brake system for a fault.
Old Oct 10, 2012 | 07:03 PM
yupzz.. i know when the first time i started ignition all part at das board light up and 2-3 second go out. but some times when i driving suddenly ABS light up and then few minute anymore light up.. im confuse and worry. what's happen with my car?? when i checked my breake can function very well...
anymore advice.. pleasee??? thankssss
Old Oct 10, 2012 | 09:39 PM
difflock54's Avatar
Have you checked your brake fluid level? May need a top up.
Also look for any visible signs of brake fluid leaks to brake hoses etc.
Failing that it's probably to do with an ABS module problem or a loose connection.
You would need to get car scanned for a fault code with a Volvo dealer or someone else with a scanner reader, preferrably one that can also reset ABS system.
Old Oct 11, 2012 | 08:36 PM
okey i will check first.. thanks your advice. but how much $$ for scanner and reset ABS modul ?? I spent $$$ for repair my car... thanks..
nealeas
Mar 24, 2018 09:59 AM
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
piv15
Nov 3, 2012 07:56 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
