Manual Climate Control (1999 S70)
Old Oct 15, 2013 | 04:46 PM
volvoman63's Avatar
Default Manual Climate Control (1999 S70)
Greetings...new member here with hopes that I can find some assistance. I have a 1999 S70. The drivers side manual temp control will not move (stuck in the far left cold position) and the A/C switch is acting up, so I believe that I need to replace the Manual Climate Control Module. Since it isn't the ECC, can it just be replaced with the same part number or is there a need for software to be loaded after replacing? Thanks in advance for any help.
Old Oct 16, 2013 | 04:21 PM
volvoman63's Avatar
Update...I don't need the actual Manual Climate Control Module after all, but I need the plastic part behind it that has the temp controls (where the cables connect). Does anyone know how to disconnect the cable that connect to the driver and passenger
temperature controls?
bestharry
Oct 10, 2025 11:34 AM
reecesp1eces
Feb 3, 2014 12:20 AM
volvo4mylife
Sep 14, 2011 08:07 PM
Vilenica
Apr 3, 2011 04:57 PM
jfikentscher
May 31, 2006 09:58 PM
