not wheel bearing not cv joint
it sounds as if something is grinding or rubbing like a really bad wheel bearing it quiets down at 50 mph or (80 klicks) and I found out I had a bent rim on the inside but I never felt any vibration,the bent rim took out the wheel bearing and the cv joint but after changing both I still have the same sound. I would like an idea before I take it in because I don't want them replacing 50 parts to find the problem
I has a scrapping sound like bad brakes..it was abs reluctor ring. Stick your head in there and rotate wheel and look where the ring is. Look for shiny metal on the ring.
I've put on a new cv joint and it has a new reluctor ring on it and backing plate not touching the rotor I had 2 mechanics say I might have a bad wheel bearing even though its new but its running 1 degree cooler than the other ones so I cant see it being bad or it would be heating up (tested with a laser therm.)
Arch Stanton
Jan 8, 2014 09:15 AM
