Oil smels of gas
Hi Volvoforum,
I need help sorting out my engine problem. I have an 850 t5 2.0 the oil is smelling of gas and when I drive the car there is a point on the gaspedal were nothing happens at all. When I give it full speed first second itīs all good when I reach third gear the engine cut the fuel or ignition not a nice feeling. The sparks is sooty and they are new orginal volvo for the B5204t engine. I did a compression test all five were around 12 diffrence smaller than whats "criminal" I have checked all the vacumlines several of times, I have complete new ignition system cables+rotor+cap and new fuelfilter+new Maf+cranck case sensor+camshaftsensor shifted+new used fuelpump and the pressure is ok after the book I even shifted the fuel pumpregulator... Next step is to take the injectors out and see if they are dripping, but I mean would it be possible that all five is bad? I would take the intercooler down and have a look at it to, try with blowing air into it and check for leakage. The errors it gives is 414, 231 to high gas and instrument temperature Any good sugestions I would be happy to hear from you Guys:) Regards from Copenhagen |
You need to check the injectors; my guess would be at least one of them is leaking.
I didn't understand your compression test numbers? What were the pressure readings for each of the cylinders? Running the engine with fuel diluted oil will make it run like crap and cause increased engine wear; get it fixed asap! |
Author
Originally Posted by gdog
(Post 342738)
I didn't understand your compression test numbers? What were the pressure readings for each of the cylinders? Running the engine with fuel diluted oil will make it run like crap and cause increased engine wear; get it fixed asap! when I took the protection plate of underneath the radiator grill I could see that a stone or something must have hit the buttom of it and made it open in the corner were the plastic and aluminium is put together. Vaouuuu I was more than happy when I saw that was it.:) Gettin a second hand one tommorow plus new oil and filter then it schould be sweet ass and ready for Rollin Thanks for the help BR Sune Brooker |
