Premium Tech Tool Volvo PTT Online Installation Service
Old Sep 14, 2022 | 02:27 AM
charlesbeb's Avatar
Default Premium Tech Tool Volvo PTT Online Installation Service
Volvo Premium tech tool 2.7.107 development version supports EURO5/ EURO6 Programming, add new option for filter control unit and parameter group, development version database allows to Diagnose, Change Parameters, Clear DTC, Calibration, Test, Programming, Change Chassis ID, and many other features, remote installation is available.
Volov Premium Tech Tool Overview
First, Premium Tech Tool is a tool that supports the repair and diagnostic process. It was developed to make repair shop tasks easier and more efficient.
Second, TT can be used in the repair shop, out in the field, at the roadside, or during test drives. TT is a diagnostics application that covers the whole repair process through the use of plug-ins.
Three, With TT you can diagnose, test, calibrate, and program a product. A product could be a vehicle, engine, or a machine. TT also provide functions for updating the tool, communication with the product, and other external applications. The set of plug-ins, user authorizations, and available languages is adjustable to provide every user with what they need.
Basic Workflow In Premium Tech Tool
• Identify a product.
• View information history.
• Diagnose a selected product.
• Test a selected product.
• Program a selected product.
• Calibrate a selected product.
Supported companies and electrical systems with PARAMETER PROGRAMMING:
• Volvo Trucks (Older electrical system, Vehicle electrical system ’98);
• Volvo Trucks (VERSION2, VERSION3);
• Volvo Trucks (VERSION4 – FH4/FM4);
• Volvo Buses (Conventional, Multiplexed, Multiplexed v2, Multiplexed v3);
• Volvo Construction Equipment;
• Volvo Penta (VERSION2, VERSION3);
• Volvo OEM Component Customer (VERSION2, VERSION3);
• Mack Trucks (V-MAC I/II/III, ITC, IV, IV+);
• Renault Trucks (VERSION2, VERSION3, VERSION4);
• UD Trucks (VERSION2, VERSION3).
WORK WITH USA TRUCKS WITHOUT PROBLEMS
New Features and Changes In New Relesed Premium Tech Tool 2.7
• The odometer (mileage) value of the connected product will now be shown in the Product Identification screen as well as recorded into Product History log.
• Tech Tool will now automatically detect any VOCOM adapter connected via USB.
• New version of VOCOM II firmware.
• Tech Tool now has the ability to read and clear fault codes communicating on J1939 (Example: Bendix Fusion system). Note that all fault tracing for Bendix Fusion must be done using Bendix ACOM.
• Updates to the Windows driver software (SW) and hardware device firmware (FW) for the Vocom II (88894000) have been released to address issues related to J1939 communication, operational performance and automatic update of Vocom II FW. These updates are found in Vocom II SW version “4.0.0.925” ALL CHANGES CHANGES YOU CAN FIND IN ATTACHMENTS
Tech Tool 2.7 includes the Vocom II version “4.0.0.925” with updates being handled in the Tech Tool Client Update (CLUP). The Vocom II will be updated automatically from TT 2.7 forward.
Volvo Premium Tech Tool 2.7 User Tips
1. Online installation directly via volvo server (Not need any files or links to download) – support for USA trucks also.
2. This Module is “Getting orginal File” from Volvo Server.
3. This Getting File for Chassis Id So You need Firstly Connect Truck With Tectool After Getting File From Volvo Server.
4. Dont need Online account From Volvo.
5. Need delete all the old version of PTT on laptop and install our new version
6. System requirement : Windows 7 32/64 Ultimate or Proffesional or Enterprice With service pack
Note: Tech Tool does NOT support Windowns XP. DONT WORK with HOME Edition.
Recommended Hardware Requirements:
Computer/Processor: Inter Core i5 or AMD FX 8 Core Series
Memory(RAM): 6GB more memory improves performance
Hard Disk: 120GB SDD (Solid State Drive) of free hard disk space
Optical Drive: Internal/External DVD x8 drive
Display: XGA (1024Χ768 pixels) or highter resolution monitor with 32 bit color settings
Input Device: Keyboard and mouse or compatible pointing device
Internet Connection: Network 10 Mbps or higher speed adapter or WLAN
Miscellanceous: USB interface required.A battery-pack that may provide 500mA via USB
Enjoy!
Old Sep 14, 2022 | 09:22 AM
Are you selling a product here? If so, this belongs in the market place board.
Old Feb 13, 2023 | 08:24 AM
charlesbeb's Avatar
Volvo PTT Software Vehicle Model Coverage:
Volvo Trucks (VERSION2, VERSION3 – PARAMETER PROGRAMMING);
Volvo Trucks (VERSION4 – FH4/FM4 – PARAMETER PROGRAMMING);
Mack Trucks (V-MAC I/II/III, ITC, IV, IV+ – PARAMETER PROGRAMMING);
Renault Trucks (VERSION2, VERSION3, VERSION4 – PARAMETER PROGRAMMING);
UD Trucks (VERSION2, VERSION3).PARAMETER PROGRAMMING);
Note:The free download software haven’t been verified on above vehicle models,the pay version does.
Volvo PTT Free Download:
2022 Volvo PTT 2.8.150+APCI Plus 2022/11+Devtool 100% Work (paid version 100% WORK)
Old Feb 18, 2023 | 09:12 AM
charlesbeb's Avatar
how ot use Volvo PTT Tech Tool to change chassis ID for Volvo FH12 version2 truck.
WARNING:
Please change original ID to a REAL chassis ID (it need exit),otherwise you will lost communication with it after changing.
Procedures:
Connect Volvo Voccom adapter to truck/ECM
Run Volvo PTT software to identify truck models or input by manual
Select “Program”,then select “Parameter programming” at “Service and maintenance” option
Click “Start”
Select “All levels” and then click “Play”
Check the box for option:
The engine must be switched off
The parking brake must be applied
Now here you will find option “DR Chassis ID” is gray
You can not change it current.
Back to desktop to run Tech Tool Developemnt tool
Input “Chassis” to search,then select “DR Chassis ID”
Then click “Set Programable”
It will show you “Success!Parameter updated”
Back to PTT software
Click “Stop” button
Then click “Play” again
After control units data reading finish,you will find “DR Chassis ID” shows as black
Now you can edit it.
Old May 6, 2023 | 09:55 PM
charlesbeb's Avatar
Premium Tech Tool it’s a great tool, but are there better alternatives out there? Is it the best option for your situation?
Old Jun 28, 2023 | 12:02 AM
24901049's Avatar
<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->Discovering the website's SQL Homework Help service was a game-changer for me. With complex SQL assignments looming over me, I needed assistance from experts in the field. The platform provided an extensive network of specialists with in-depth knowledge sql homework help . Each specialist's profile showcased their proficiency, educational background, and experience in handling SQL homework. Through the website's intuitive interface, I was able to connect with a skilled professional who delivered comprehensive and high-quality SQL homework help. Thanks to the website, I was able to overcome challenges and excel in my SQL coursework.
Enjoy!
thanks for info
Old Feb 24, 2025 | 12:52 PM
Ranja's Avatar
Default Online tech tool uk version
Hey pls advice if you would have online version of tech tool ?
As I want to update some modules and so on .
And I also do play with hp on my trks to get better fuel efficiency.
Let me know.
my email address is onkarzm@gmail.com
charlesbeb
Apr 13, 2023 02:03 AM
obdvip
Apr 12, 2021 04:22 AM
solarant
May 22, 2015 06:45 AM
Templar1
Jan 18, 2014 07:41 PM
atikovi
Oct 6, 2010 02:53 PM
