S60 Aircon failing, out temp > 30°C
Old Mar 30, 2012 | 03:00 AM
Cecil0Lancaster's Avatar
Default S60 Aircon failing, out temp > 30°C
Hi,
The aircon in my 2003 S60 2.4 fails when outside temp approaches 30°C.
It works fine for a while, then the compressor shuts down, and delivers warmer air via the vents.
The compressor then kicks in again for a few minutes after being off for 10 minutes or so. --> Typical of expansion valve freeze-up.
In cooler weather it seems fine, maybe because the compressor is called on to run less.
It is probably coincidence, but thinking back it possibly started after I had the windscreen and drivers side (right hand) window replaced. The side window is Volvo, but the windscreen not, and less tinted. I accept that it will allow more heat into the car, but the a/c should handle that?
I am familiar with the older (electromechanincal controlled) systems, but have been out of the refrig game for many years now. Anyhow I have checked all the "traditional" things, compressor comes on, pressures seems OK, condenser fan on, HP pipes and condenser warm, suction pipe cold, then the compessor shuts down.
I am not sure why, the I suspect that the car's computer computer nowadays controls these things, and I do not have access to it.
Can anyone advise an easy way to access the computer and how to determine the cause of this trickery?
Are there common culprits like a thermostat or other sensor that tend to fail? How does one confirm these?
Can it be caused by differentials in teperature, inside, out, engine, dash, coolant, condenser, evaporator, whatever.
I am reluctant to go to the agents, around here they are notorious parts replacers and I cannnot afford to replace a series of good parts.
Preferably I also do not want to follow the same elimination process.
Out of desperation, I have resolved to evacuate the system this weekend, draw a proper vacuum to get rid of any moisture, and re-charge with 1000g fresh (and dry) R134A.
Any experience shared will be highly appreciated.
Kind Regards
Cecil
Old Apr 2, 2012 | 12:46 PM
Hi Again,
subsequent to further checking it appears that the ac stays on from cold start, but afer a warm stop after say 20km to fill up, it stopped.
The engine is now warm, and the cooling fan is not running? I think it should, and was not comfortable letting the car idle and haet up more.
From this I would guess that the AC gets disbled because of excessive engine/coolant temp? - and it makes sense.
How can this be confirmed?
Is there possibly a relay that failed, if so, which would be the probable suspects, and how to check.
Thanx & Regards
LeeJane
Mar 19, 2013 02:32 AM
nickdog
Jul 5, 2008 10:59 AM
filip
Apr 13, 2008 11:14 AM
dj296
Dec 22, 2006 10:07 PM
cetaphil
Sep 20, 2004 03:24 PM
