S60 Instrument cluster catashtrophe
I have a 2002 S60 with cluster trouble like others I have read about. Drops dead, pops back on. SRS message appeared. I had a recall update for the limp home mode glitch at146k. Now at 147k transmission began behaving badly, I had a tranny wiz drive it. He felt there were no mechanical issues with it. Felt like it was missing software acclamation or possibly network disfunction through the cluster. Left his yard and within 2 miles didn't shift out of 2nd and just rev'd. Put it in park and shut off tried again. Very little movement so I got it towed vs burning it up. Stealership wants to start with the instrument cluster (because a second use cluster doesn't work) at a castrating $1,400.00 . Has anyone else experianced problems like this after a software upgrade? I'm hoping this isn't a segway into a new tranny.
S60 2003 instrument cluster goes dead
Hi:
I do have similar problem but with S60 - 2003. The instrument cluster goes dead and when is alive that SRS airbag message shows up. Looking for a solution to this problem as well. |
S60 2002 Instrument Cluster
I have exactly the same problem, does anyone have an advise? do I have to change the whole cluster or is it a minor problem????:( Thanks
sounds like u have more then 1 problems, u need to isolate them first. first a cluster will not give a shifting problem, sound like u may new a tranny. on the other hand, i m kind of confuse of what really is the problem with your cluster?? do you mean you have a srs light on or your cluster just cut out??
SRS - airbag service urgent is stuck in the messzge dispaly only. I do not think there is any problem with it just the cluster panel malfunction casuses it to appear there.
what's the dtc??
My 2003 v70 instrument cluster started to go blank intermittently and then completely died. Dealer told me it needed to be replaced at a cost of $1,500.00. Too much for me so I took off the front cover panel and found that by sqeezing on the top left corner the cluster would turn back on. Most of the time the speedo and tach would not work but the gas guage, lights, blinkers, temp etc would. I am not handy so my buddy took out the cluster and fixed it in an hour. Just needed a thin spacer installed between the rear cover and the circuit board.
Great I will try that! Thanks so much!!!
Does you have instruction on how to remove the front cover panel so that I can try sqeezing on the top left corner the cluster to see if it solve my problem as well. I have the exact same problem, cluster goes dead, pops back on occasiionally and now shows a SRS fault in the message center
Thanks, Kevin |
Originally Posted by kdaide
(Post 250695)
Thanks, Kevin |
