Seperating Control Arm from ball joint
Old Oct 29, 2006 | 01:14 PM
NYSpeedRacer's Avatar
Default Seperating Control Arm from ball joint
What's the best method to seperate the control arm from the ball joint? I have pickled fork but that doesn't seem to do it? any other suggestions?
Old Oct 29, 2006 | 11:02 PM
Default RE: Seperating Control Arm from ball joint
What year and model is it?
If it is a newer 850,S70,S40 you have to replace the entire control arm.
Old Oct 29, 2006 | 11:17 PM
I apologize I wasn't clear enough regarding my problem. I have an 01 V40 and I do have the new control arm, but I can't seem to figure out how to seperate the ball joint from the Wheel. I got the two bushings loose, but can't seem to take the other part off.
Old Oct 29, 2006 | 11:46 PM
Try hitting the hub a couple of times with a big hammer carefully.
Don't damage the hub but hit it a couple of times to try to loosen it up.
dpvovo
Feb 18, 2019 07:41 PM
KeithS60&V70T5
Nov 14, 2009 12:24 PM
shop2
Jan 22, 2009 08:48 PM
Super20
Jun 26, 2007 06:16 PM
rejeep
Nov 3, 2006 07:41 PM
