Shift knob shroud replacement
Old Dec 7, 2012 | 08:34 PM
Sir Vivor's Avatar
Default Emerg brake shroud replacement
Okay, this is not the usual mecha issue, but an aesthetic interior one.
The 2001 V70 I bought must have had a fatarse driver because his getting in and out wore holes in the leather shroud of the brake lever. As the sole issue I have with the interior condition, addressing it will usher in contentment.
There is an obvious seam round the plastic base plate surrounding it, but rather than rashly start prying at that, likely breaking something, I thought I’d ask if anyone knows the subtle trick to lifting it out in order to access the shroud.
Fairly confident that the replacement shroud from Göteborg is some absurd figure like $118, my plan is to task an upholsterer with stitching up a new one.
Old Dec 11, 2012 | 02:47 PM
01_fast_ride's Avatar
I thought that piece just snapped into place, so don't be afraid of tugging or prying on it.
Old Dec 15, 2012 | 08:57 PM
Sir Vivor's Avatar
Your use of past tense suggests you no longer hold the same opinion.
Permission to pry and hack away like Conan?
Note: I asked a moderator to change the name of the thread from ‘shift ****’ to ‘brake ****.’ Not having done so misfiles this thread, as it were.
Old Dec 16, 2012 | 04:36 PM
I went out to my car just now. It pulls out vertically. Grab the edge near the cup holder and gently tug up on it. Just lift straight up. Mine was held in place with three small clips. The other side is held in place with a series of fragile plastic tabs.
joseangel
Dec 1, 2019 07:55 AM
Spyros
May 23, 2014 11:03 AM
mpower916
May 16, 2012 02:26 AM
jfspring
Jan 29, 2006 12:00 AM
jcmartin
Sep 20, 2005 08:54 PM
