Turning off Maint. Req'd Msg & TPMS service msg on a C30
Old Dec 4, 2008 | 09:39 AM
fstrdr's Avatar
Default Turning off Maint. Req'd Msg & TPMS service msg on a C30
Hello, I would like to know, how to turn off the Maintenance Require Message (ie oil change), as we did it ourselves, in our '08 C30. Also, is there a way to turn off the TPMS system message, as I don't have sensors on our winter tires, then turn it back on in the Spring when the factory wheels/tires go back on? Thank you very much for your help.
Old Dec 4, 2008 | 10:01 AM
bluemagicbus's Avatar
Default RE: Turning off Maint. Req'd Msg & TPMS service msg on a C30
Hi, you might want to try the procedure below which is for the XC90 and some others. It might work for the C30 as well.
https://volvoforums.com/m_31346/tm.htm
No idea on the TPMS, but since you aren't the only one that switches to winter tires you might want to check with your dealer and they just might tell you.You might also try the search function (if you haven't already) here on the forums using key words like tire pressure or TPMS and maybe one the info is on one of the other boards.
Good luck, and let us know what you find out, and if the XC90 reset procedure works for you as well.
bmb
FredRydr
Nov 13, 2016 06:32 AM
jcdiaz31
Oct 11, 2013 09:05 AM
jools constant
Jul 25, 2011 07:42 AM
S70Kid
Feb 21, 2007 10:21 PM
j62k
Jan 6, 2007 05:48 PM
