Used car blues
Just purchased a 1999 V70 station wagon. Today the dash lit up like a Christmas tree with the ABS, ETS, SRS, brake indicators lit plus a flashing "up" indicator.
I pulled into AdvanceAuto and the connected their scanner and came up with the following codes: P0600 P1059 P1019 P1081 P1057 P0722 Can someone please decipher these for me? Thanks Richard |
Originally Posted by Rdhcincy
(Post 314026)
I pulled into AdvanceAuto and the connected their scanner and came up with the following codes: P0600 P1059 P1019 P1081 P1057 P0722 Can someone please decipher these for me? Thanks Richard You may also have a faulty ETM, another known problem, in which case you should install the upgraded Xemodex unit. Let us know what you do and how it works out. P0600 Serial communication link malfunction P1059 MIL requested by the throttle unit P1019 Electronic Throttle Module ? P1081 Immobilizer communication P1057 ABS module ? P0722 Output speed sensor circuit no signal |
Took the car to Volvo dealer who scanned the codes for me, (free), whoop! They came up with 3 ABS codes and CM-530D DTC in transmission control module,(TCM) - Faulty siqnal. The overall remedy they suggested replacing the ABS module and the ETM. I don't know what that TCM fix would be unless it's related to the ABS or ETM.
Any ideas? |
Hi Richard, welcome to VolvoForums.
Usually when the dash lights up like a Christmas tree it's the alternator going out. I would have that checked first. If the alternator goes and it's not supplying the proper charge to the battery, that will wreek havac on a car that depends on certain voltage to operate electronics. A lot of people call the ETC and TCM the same thing. Electronic Throttle Control and Throttle Control Module. I'm glad I don't have one. |
redone
to me from me
