V70 Diesel
Old Aug 5, 2021 | 05:22 PM
markchaplin's Avatar
Default V70 Diesel
Filled car with diesel. began to idle lumpy after a couple of miles (Misfire) and yes it was Diesel
Accelerate on to duel carrage way then lost all power, Engine stopped and would not restart ( coasted to side of road)
Any thoughts?
Old Aug 6, 2021 | 10:15 PM
I would suspect contaminated fuel - (I trust you have a diesel engine in your car, I once filled my m5 with water contaminated gasoline - car drove a mile or so before it stopped)
Unfortunately that usually requires draining the tank and since there is no drain - requires tank removal to empty the contents. And clean the contaminated fuel from the rest of the fuel system.
Old Aug 10, 2021 | 10:48 AM
firebirdparts's Avatar
I wouldn't be shocked if you got some water. But honestly, it could be anything.
Old Aug 14, 2021 | 09:22 AM
donf's Avatar
Just wondering here - had the OP not mentioned just refueling, what would be the responses? Likely someone would say to check the fuel at the engine . Easier than dropping the tank. While I agree that bad fuel is most likely the culprit, I think that simpler and easier diagnostics would be in order first.
Old Aug 14, 2021 | 02:56 PM
I was just suggesting a possible logical cause - I usually leave the diagnostic process up to the OP unless they ask - for many times the OP is just looking for possibilities/knowledge before their car is taken to a shop. If they ask, I'll give suggestions to the best of my knowledge.
I thought it would be helpful to be prewarned of the complexity of tank removal - when the repair estimate comes back for many many dollars/pounds/euros. Certainly not suggesting that would be the first step.
Old Aug 14, 2021 | 11:12 PM
donf's Avatar
Sorry hoonk, I should have known better.
While we are just "supposing" here, since I assume the water sinks down to the bottom of the tank - any chance he could suck that sucker dry from the fuel filer inlet a few tanksful of fuel?
Matt Morriss
Volvo C30
Dec 8, 2016 12:08 PM
golfergti
Mar 4, 2011 01:28 PM
spot
Mar 29, 2009 01:58 AM
Ahmed
Sep 1, 2006 02:38 AM
Ahmed
Mar 15, 2006 05:39 PM
