volvo maintenance
Old May 5, 2009 | 10:42 AM
mango's Avatar
Default volvo maintenance
Hi, I am new to this site. I just had a light come up on my volvo that says it's time for routine maintenance. My question is do I need to go exclusively to a Volvo mechanic for maintenance or can I go to any mechanic. Also, I just recently had my oil changed and levels checked. Is it necessary to do these routine maintence checks if I am taking care of oil changes?
Old May 5, 2009 | 11:17 AM
Somthngfrce's Avatar
I call that the "oil change" light. You don't need to go to the Stealership to do so. As long as you are following the maintenace schedule that Volvo has you should be ok. Some shops might have the tool to reset the light. Check with your mechanic. Otherwise you will either have to look at the light or go to the Stealership and have them reset. Personally I don't use the dealer, So I know someone whom has the tool to reset since I got tired of looking at that light! Good Luck!
Old May 5, 2009 | 12:11 PM
mango's Avatar
thanks for you help.
elguzzy
Jan 1, 2009 06:05 PM
thepetesaguy
Dec 4, 2008 10:15 PM
Cappachinoo
Mar 4, 2008 10:41 PM
pete22us
Oct 25, 2007 09:41 AM
afton
Oct 24, 2007 04:29 PM
