Xc90 ac not cooling on idle
Old May 13, 2021 | 04:13 PM
Safemax's Avatar
Default Xc90 ac not cooling on idle
Hi all, please I have Volvo xc90 2005 model, the ac does not cool while running idle state but work pretty fine while on high way please what could be the problems and what is the solution?
Old May 13, 2021 | 07:32 PM
There are 4 engine choices for your region - what's yours? The 6 cyl compressor has a variable displacement valve than can limit ac function when it has a problem - or you could just have a slow leak and be low on refrigerant on the cars that don't have a variable displacement valve. .
Old May 14, 2021 | 02:06 PM
Safemax's Avatar
Mine is 5Cyl
Old May 14, 2021 | 02:50 PM
Mine is 5Cyl
The 5 cyl does not have a variable displacement compressor - I would first have the system properly recharged - with the right equipment when the refrigerant is reclaimed - they will know if it was low. There are many areas they leak slowly -
Old May 15, 2021 | 03:52 AM
Safemax's Avatar
All the leakages has been confirmed and repaired and the gas refilled the third time now but does not cold as expected when in idle, but if am on the high way it works pretty fine, I was told that the pressure from the compressor is low and need to be replaced.
I just want to get an expert advice to know what could be responsible before going ahead.
Old May 15, 2021 | 01:23 PM
ssicarman's Avatar
Are the cooling fan/s running when you are stopped/at idle?
What are the pressures high and low side at idle?
Refrigerant is charged to the correct amount by weight?
Going to assume a (if installed) clean or fairly clean free flowing cabin/dust/pollen filter that allows good air flow through the HVAC system.
Old May 28, 2021 | 12:41 PM
Safemax's Avatar
Good day all, I just discovered something on My car A/C, the third line seat A/C pretty chilling but the front and the middle A/C are not, pls what could be responsible for this?
Old May 31, 2021 | 12:04 PM
Safemax's Avatar
Default Mr.
I just discovered in my xc90 that the ac in the third back roll is working(chilling) perfectly but the front and middle roll does not cool at all.
please what could be responsible for this and how do I rectify this? I need to have the knowledge before taking it to ac repair this time, they have changed the compressor twice before I actually notice that the back ac is working, it means it has nothing to do with the compressor.
Old May 31, 2021 | 02:28 PM
The AC system has two moving parts - the compressor and the expansion valve. The expansion valve sprays the refrigerant into the evaporator at a controlled rate, and as the refrigerant expands - it gets cold. Like in a bathtub - you turn the lower tub filler on and get the water the comfortable temperature - then when you divert the water to the showerhead - that spray is colder.
Your car has 2 evaporators and 2 expansion valves - It's possible the front valve is bad or clogged not allowing refrigerant to flow. If clogged the question is what/where did the material come from that clogged it? Sometimes if a compressor internally self destructs it can send metal shaving throughout the ac system - and clog stuff up. Obviously the rear one is working. I have not replaced one (in a xc90/v70/s60) but looking in the flat rate manual and the replacement instructions - Volvo suggests .7 hours warranty time to replace the valve, not including evacuate and recharge. So I would imagine someone would charge a total of 2.5 - 3 hours total.
Old Jul 17, 2021 | 03:51 AM
Safemax's Avatar
Default XC 90 starts and off
Hi all, I have this xc90 05 medel, recently I notice that when the engine has cool down or when starting in the morning, the engine will not start immediately, after tuning the ignition key it will start of off, at times it will start on third trials and when it start it works normally and it starts normal when the engine is hot or warm, pls what could be the reason for this.
Old Jul 22, 2021 | 09:48 AM
donf's Avatar
don't know why this is posted as an addendum to your AC problem.
Cold start slow, hot start fine - possible fuel pressure issue. Your pump/check valve my not be maintaining enough pressure overnight. I'd start off with checking my pressure and seeing if it drops significantly over time. That's easy to do, cheap, and a good starting point.
metamict
Aug 17, 2023 07:59 PM
Safemax
May 13, 2021 04:12 PM
hughey99
Aug 13, 2010 07:28 PM
jtl180
Jul 29, 2008 09:07 PM
otis44
Sep 15, 2007 08:49 AM
