How big is the MAF sensor diameter?
I'm considering using one of these for a megasquirt install and want to know how big the Mass Air Flow sensor is, like off a Bosch LH system?
lol take one and measure it.:rolleyes:
Thanks, didn't think of that. Oh wait, don't have access to one.:( Don't want to go the MAP route that 99% of the other MS users do.
Need to know as this will be a swap from different car to mine and what the intake size will be. Anyone have a junked car with the airbox off or your car being worked on? Thanks. |
which model are we talking about here?
if it is LH2.4 then you can run the 3" maf from a 960. iirc the stock size is ~2.75" |
Perfect, thanks.
Mass airflow sensors come in different 'sizes' to accommodate different amounts of airflow. Each MAF has a certain amount of air that it can 'see.' For cars that are running high-boost, high horsepower applications, larger sized MAFs are necessary to be able to convey the right signal along to the ECU.
