Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
S40 T5 Baclpressure ?
Old Nov 9, 2011 | 09:17 AM
Ouboet's Avatar
Default S40 T5 Baclpressure ?
Hi
I was surfing the internet for a proper performance exhaust system for my 2008 Volvo s40 T5 and would like some advice please. Seems that mostly a 76mm (3") downpipe is used and then the rest of the system is reduced to 63mm and the cat is also removed and replaced by a catfooler. I have however came across 2 chaps that said they have experienced boostcontrol problems after installing the 76mm downpipe. Apparently the size of the downpipe helps to control the amount of boost ? I was also advised to do the downpipe and catfooler but to not replace the backbox to keep the backpreassure correct by some others ?
My goal is to get more power and would like some of the forums expertise please.
Old Nov 10, 2011 | 10:23 PM
ShowTek's Avatar
Well you want to eliminate back pressure, but not completely.
What tune are the guys who you are talking to using? if it's a stock that means they have other issues and it's not the DP's fault.
On the other hand i am soon making custom 3inch DP's.
Old Dec 1, 2011 | 06:20 AM
S70driver's Avatar
You want some backpressure but not a lot. So install a straight through desgin free flowing muffler like Magnaflow or BORLA is what your going to want to look into & or an equivalent.
As for the 3" downpipe to control boost I have never heard of this. It's a metal pipe it doesn't control boost period. Your ECU and wastegate do that. Now it may help it boost a little sooner (Spool Time) . But that is only because more airflow can get through. Your not going to gain "BOOST" by adding a downpipe. You'll gain HP and performance but if you want more "BOOST" you need a Boost Controller and or an ECU upgrade (IPD USA, BSR, RICA, SPEEDTUNING USA, UPSOLUTE...).
When you do the downpipe and catback system you want mandrel bends for a free flowing exhaust crush bends will hinder performance.
Old Dec 8, 2011 | 07:42 AM
Ouboet's Avatar
Smile
Thankyou for the feedback, much appreciated.
Old Dec 8, 2011 | 07:45 AM
Ouboet's Avatar
Old Oct 9, 2012 | 06:49 AM
carol123's Avatar
What are the advantages and the desadvantages of the Volvo S40 2002?
I am planning to buy a Volvo s40 2002;
I have no experience about Swedish cars at all
I just want to know, What are the advantages and the desadvantages of the Volvo S40 2002?
______________
cialis
