Volvo v70 2.5t for sale in georgia
2006 Volvo V70
  • 2006 Volvo V70 - Volvo v70 2.5t for sale in georgia - Used - VIN YV1S W592 X625 89 - 118,600 Miles - 5 cyl - 2WD - Automatic - Wagon - Black - Atlanta, GA 30305, United States
    $1,900
    • OBO • Trade
  • Location Atlanta, GA, 30305, USA
  • VIN YV1S W592 X625 89
  • Mileage 118,600
  • Engine 5 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Wagon
  • Exterior Color Black
Any reasonable offer considered for a quick sale.
Private seller. have title.
Engine turns but no start. AAA Mechanic said its timing belt.
Car was very well maintained until a timing belt came off. The mechanic did not do a good job when kit replaced 1 year ago.
Selling this car as a PARTS CAR or Mechanic special.
Body and interior excellent condition , very clean car.
No dents , dings or rust. No tears in the leather seats.
Electronic Lockable Gas lid !
Working Sunroof
Power seats and everything, Fog lights, daytime lights,
 I was planning to keep the car so the last 2 years following done (have receipts /record) services ;
Replacement of complete 10 pcs suspension.
New battery
New tires, lifetime alignment,
New serpentine belt,
New ignition coils,
New fuel injectors,
New O2 and camshaft and other sensors ,
New spark plugs,
Fully synthetic oil,
New oil system breather kit,
New alternator.
New water pump, new timing belt kit.
... many more items.
Tow away.
Old Jul 20, 2022 | 01:33 PM
If the timing belt came off you the car will need a valve job to replace the bent exhaust valves. Given the car's value and cost to repair, I'd say this is clearly not a parts car and would be worth fixing the top end. I think you can take "new timing belt kit" off the list of parts installed :-)
Old Jul 20, 2022 | 05:36 PM
VoVosouth's Avatar
Thanks. It's easy to like Volvos' Your repair tip is encouraging. I've just checked my car and the timing belt did not come off, not broken either. But a bit loose.
The engine turns but no start ; there was an odd "backfire" sound though.
Old Jul 21, 2022 | 09:08 AM
There is some hope then! Its possible the timing belt has slipped a notch or two which can cause the no start condition. You can have a compression test done to see if there's any compression or have an inspection cam look for bent valves or ding marks on the pistons. If there is some compression (if the timing is off, there will be some loss of compression but not all) you can have the valve timing checked and reset to see if that restores the engine back to normal. This may cost you a few hours of shop time unless you can do the basic testing yourself. Note that for a turbo engine, the compression should be in the 150 PSI range and my guess is you'd need something over 100 for the engine to start. If you see something like 60-80 PSI across the board then I'd look into having the timing reset (unless the cam shows valve or piston damage ).
Old Aug 22, 2022 | 04:13 PM
chandlerm's Avatar
Is this still available?
