2005 Volvo XC70 Engine
Old Oct 20, 2021 | 02:30 PM
JordanP's Avatar
Question 2005 Volvo XC70 Engine
I have a question about the size of turbo in my Volvo. I've done quite a bit of research and i cant seem to find out how big my turbo is. If it helps, i can tell you its a light pressure turbo. If anyone can let me know what the size of turbo would be, that would be great.
Old Oct 21, 2021 | 03:45 PM
I believe the LPTs use a TD04L-14T and HPs use a 16T. What is the badge ie 2.4T or do you know the engine code? (look for a sticker on the engine / timing cover with something like B5244T2 etc or find the code from the VIN (positions 6+7 are a two digit engine code that will map to the longer form).
Old Oct 21, 2021 | 09:10 PM
JordanP's Avatar
The sixth and seventh digits of the VIN are 59. There is no badge anywhere on the car that says something like #.#T.
Old Oct 22, 2021 | 11:59 AM
59 maps to the B5254T2 (2.5T) engine. You can google for details but from what I've seen you have the 14T turbo. In TD04 coding, the numbers (13,14,15,16 etc) refer to the pumping capacity of the turbo and to the housing design (ie flange types). You can buy replacement compressor/impeller blades to upgrade or you can research on compatible models (ie similar flange designs). Or you can trust that your turbo has some extra untapped potential and find an ECU tune specific to the engine model.
Old Oct 22, 2021 | 02:16 PM
JordanP's Avatar
Thank you for the information.
Nick2398
Sep 17, 2016 04:35 AM
phil.crawford1
2001-2013 model year XC70
Jan 10, 2013 07:54 AM
jbarker2000
Oct 31, 2010 12:41 AM
supergimp
May 31, 2010 12:20 PM
8blade6
Jul 17, 2009 05:35 AM
