2007 v50 anti-skid wipers and blinkers
Old Apr 7, 2023 | 01:26 AM
WolfBrick76's Avatar
Default 2007 v50 anti-skid wipers and blinkers
Hello aficionados,
My 2007 V50, had the anit-skid service pop up, then less than 10 minutes into the drive the windshield wipers began to go off and so did the blinkers. They did not stop going until I shut off the vehicle and turned it on where 5-10 minutes later it all went off again. I recently (2 weeks ago) had the CEM cleaned and all was back to driving well. Any ideas what it could be.
I appreciate any advice you can provide.
Old Apr 7, 2023 | 08:53 AM
Originally Posted by WolfBrick76
ani-skid service, wipers, turn signals -
What does "had the CEM cleaned" mean?
Your symptoms are certainly those of a problem with the CEM - perhaps you need the CEM fixed instead of just "cleaned". A company such as xemodex could solve that if needed.
Old Apr 8, 2023 | 11:24 PM
Hello and thank you for responding.
The mechanic I used stated as they were looking for the issue, they found that there were some loose connections with the CEM, and they went one by one and cleaned the cem connections as well as checked all the grounds, on it. They went on to state that once everything was cleaned and ensured that there was no rust or debris, and that the grounds were connected as well. They stated that usually water gets in and may cause some issues such as the one we experienced. Furthermore, they stated that there was no water damaged and after all their work it was ready to drive. Since then I have driven it and it runs like a dream all good, but now two weeks later, the same occurrences popped up again.
IPD suggested that I contact the Xemodex if I need to have it worked on. I think that is what I will have to do now.
41ants
Oct 13, 2020 07:19 AM
CRamsey
Jan 25, 2018 05:09 AM
urdrwho
Aug 6, 2017 02:43 PM
sneillboy15
Aug 19, 2015 05:59 PM
a4ty4d
Jun 6, 2011 08:26 PM
