Brakes
Old Nov 17, 2016 | 05:47 AM
Nancy331's Avatar
Default Brakes
Hello,, first time here, I have a 2001 S40. Had quite a few things done to it but now it is making a lot of noise when I brake. I have a guy that is going to work on it tomorrow. Would anyone be able to recommend type of brakes or what all I should replace , it is in the front wheels. Thank you so much for your help.
Old Nov 17, 2016 | 08:16 AM
Can't really tell you if its front or rear - you'd have to look at the disks to see if there are any signs of wear (ie deep grooves). As far as the type of brakes go, you should expect to get new rotors (noise means metal on metal so the rotors are likely scored). As far as pads go, it depends on your needs. Do you drive mostly in town or highway? do you drive aggressively? OEM (factory) pads are organic and give the best feel for in town driving. Bosch sells a nice set of organic pads at a good price. Next is semi-metallic which resist fade (ie high speed braking) and produce less brake dust but are firmer at low speeds. Finally you have ceramic pads which are supposed to be even lower dust. Personally I've done all three on my s40 and 850 and I'm back to OEM organics (Bosch on the s40, Genuine Volvo on the 850) for the best feel and overall performance.
Old Nov 17, 2016 | 08:24 AM
RA061126's Avatar
Banned
everything ^^^^.
your mechanic should be able to use your vin to get the correct parts also.
Old Nov 17, 2016 | 12:33 PM
Nancy331's Avatar
Ok thank you, I was told there is a porcelain type but they are loud so I just wanted to get other advice. I am gonna check in on those Bosch , I drive highway and some small town but not much city at all. Thank you so much and apologies for putting on new member.
Old Nov 17, 2016 | 12:36 PM
Nancy331's Avatar
Originally Posted by beamer68
everything ^^^^.
Thank you, I will definately give them the vin to make sure they give me the right ones.
Old Nov 17, 2016 | 01:07 PM
RA061126's Avatar
Banned
i went with ceramic pads. less dust and work good. i used auto value brand
netconcepts
Feb 10, 2005 08:51 PM
Air Defender
Jan 29, 2005 07:45 PM
djbaines
Nov 10, 2004 06:43 PM
jhenry83
Aug 31, 2004 05:57 PM
midnight
Jun 29, 2004 05:51 PM
