Demister blows cold through middle vents
Old Nov 7, 2016 | 04:16 PM
jangrosicki's Avatar
Default Demister blows cold through middle vents
Hi
Demister in my volvo s70 is blowing cold through the middle vents even when heating is set on full. Vents located by driver and passenger door are blowing hot as they should.
My volvo has dual temp control.
Does anyone know about this problem? Many thanks
Old Nov 8, 2016 | 08:13 AM
likely something is up with the blend doors that control airflow from the heater core and the AC evaporator to the vents. I believe the S70s have 5 motors that actuate the blend doors which can either fail, get out of sync or have the actuator rods fall off or bind.
Do you have any indicator lights on the AC or REC buttons to suggest the climate control ECU has presented a fault code? (these codes can be scanned by an advanced OBD2 scanner)
merlinx
Jan 4, 2019 04:52 PM
James88888888
Sep 26, 2013 08:01 AM
tomecsi
Apr 30, 2012 08:38 AM
fastoldcarz
Aug 9, 2010 06:19 PM
copurnikus
Oct 18, 2005 04:54 PM
