Leaves and acorns in my cabin filter
Old Mar 5, 2018 | 09:28 PM
2008S40's Avatar
Angry Leaves and acorns in my cabin filter
I just bought a 2008 Volvo everything was great took it home decided to change the air filter’s cabin filter had basically what equates to a mouse nest worth of leaves and acorns in it . I Vacuumed it out put a new filter and everything is fine but now one day later The heat is stuck . No matter what button to push it wouldn’t change from floot to defrost etc....and it won’t switch to cold I have done a lot of reading and there seems to be problems like this often can’t help but think I caused any ideas on how to reverse it? I was thinking about taking out both the air filter in the cabin filter plunging my leaf blower in and blasting it probably not a good idea but not sure either
Old Mar 16, 2018 | 12:55 PM
What model do you have ??
Did you vacuum everything out before you pulled the filter? Are you sure nothing fell down when you pulled the filter out ??
Old Mar 23, 2018 | 06:08 PM
2008S40's Avatar
2008 s40 I pulled the filter out before I vacuumed anything however it seems like the filter was at the bottom of the line.gravity would dictate that the acorns and leaves came from somewhere above that’s where I would believe the switches are to monitor whether heat goes to the floor or the above registers The odd thing was when I had the filter out I turned on the heat was able to toggle from heat to air-conditioning to defrost to floor without issue once I move the car if I press the button nothing happens until I try several times once it’s in a mode it stays there
Old Mar 23, 2018 | 06:10 PM
2008S40's Avatar
Forgot to mention the nest of acorns and leaves was in the cabin filter
cal_redwood
Aug 20, 2015 11:26 PM
debargha
Feb 24, 2015 10:46 PM
bluemagicbus
May 17, 2011 07:18 AM
edahlgren
Oct 21, 2010 06:24 PM
Ahmed
Mar 28, 2008 04:22 PM
