S40 t5 2005 manual 6 speed abs light block 5th and 6 th gear
Old Apr 10, 2019 | 10:54 AM
Bg76's Avatar
Default S40 t5 2005 manual 6 speed abs light block 5th and 6 th gear
Abs light came on after changing the front passenger side bearing and at the same time i cant shift the 5 th and the 6 th gear anymore so i change the abs sensor (he was damaged) it fix the problem for 5 minute and the same problem came back
Old Apr 10, 2019 | 12:21 PM
check the wiring/connector and check that some grease didn't get on the hub or wheel sensor
Old Apr 10, 2019 | 06:47 PM
Bg76's Avatar
I checked the wiring around the connector and put some dielectrical grease in the connector and blow air where the sensor is reading around the axle but abs light still on do i have to reset the fault on the ecu or maybe its a bad sensor ?
Old May 22, 2019 | 09:34 AM
Bg76's Avatar
Default Solved
changed the abs sensor for a second time and it solved the problem it might be a bad( faulty) sensor
Capt_Haddock
1998-2000 model year V70
Jul 3, 2021 05:49 AM
mrduke
Feb 13, 2017 10:19 AM
Blkwidow
Sep 21, 2013 02:34 AM
brianb
Jan 22, 2011 04:35 PM
dwhartwell
Mar 25, 2007 03:33 PM
