Volvlo 850
Old Jul 27, 2005 | 11:35 AM
Blondy44458's Avatar
Default Volvlo 850
Hello All; found this site a little too later for my Vovlo speedo gear trip. Found the problem, but couldn't imagine finding the gear so went used instrument cluster for a good price. Now with new seats, the heater went out (or so I thought) in the driver's seat, odometer and radiator, my little wagon is back on the road. BUT, I forgot to read all the instructions on reconnectiing the battery while key was on to set air bag light to off! So I tried disconnecting the batt. then the air bags, turning on the key to #2 position as instructed, reconnecting the air bag, then the batt. but the damn light won't go off! The information here from "Tech" and others has been so good I've got to post and ask for suggestions. Can I somehow clear the computer and start over? Thanks ahead of time for any suggestions and thank you for this group! ;-) Steve
Old Jul 27, 2005 | 10:05 PM
Default RE: Volvlo 850
What year is your car?
If it is older than 1995 then you should be able to do it.If it is newer then you will need to have a scanner to clear the code.
