Volvo Penta AQ 171c marine engine problems
Old Nov 1, 2022 | 07:00 AM
lorraine73's Avatar
Default Volvo Penta AQ 171c marine engine problems
Volvo Penta AQ 171c petrol marine engine. 1600 overhead cam. Twin carburettor fitted into a 22ft windy day cruiser. It is quite an old engine. Problem is when started it runs fine from cold start. When engine has been running for 20mins or more at 20000 to 25000 revs engine starts missing or stuttering. Then have a problem starting engine when it is warm. The engine is not overheating. Have had leg serviced oil has been changed. Engine is usually very reliable. Everyone who has looked at it says it is only something small. Problem is trying to find exactly what the problem is. Any help would be appreciated
Old Nov 1, 2022 | 08:49 AM
when was the last time the engine had a tune - new plugs/wires/cap/rotor etc? Are the plugs the correct version for that engine? - I'd pop them out to see what they look like) You may also want to consider testing/replacing the coil as part of a "stage 0" tune up just to make sure the spark is correct. Next is fuel - Have the carbs ever been rebuilt? (any signs of leaking/gas smell to suggest that there's some internal leaking making the engine run rich? (cold engines like a richer mixture). What weight oil was used during the last service? Older worn engines may need slightly thicker oil to help build/maintain compression. Using the wrong engine oil weight can expose this issue.
Hocevbj
Penta
Jun 2, 2021 09:14 PM
jeffj
Oct 15, 2013 08:57 AM
volvo7070
Jul 16, 2013 05:38 PM
analogies
Mar 29, 2013 01:56 AM
262740850
Jan 12, 2013 02:30 PM
