Voz
Old Sep 22, 2013 | 05:25 AM
Voz's Avatar
Voz
Default Voz
Hi ALL
I have a 2003 S60 AWD and cannot find any posts on how to remove a turbo. Does the front diff need to be removed or can the bolts be removed from the top? Are there any step by step instructions on how to get it off the car?
Your advice will be greatly appreciated. Thanks
Old Sep 22, 2013 | 09:22 AM
I'm not sure but dig in and let us know.
Old Sep 24, 2013 | 07:53 AM
Voz's Avatar
Voz
Default S60 AWD Turbo removal
It can be removed without stripping off the diff! Wow- what a mission. The front diff presents a huge challenge with space. A few special tools: flexible 12 and 13 ratchets were critically important. I also used a 1/4" drive flexible joint to attach the T27 torx bit to remove the oil return fitting. The most difficult was the left hand lower manifold nut. There are 4x 13mm nuts holding it together.
Start with removing the pipes (intercooler, inlet, water and oil). Remove the aluminium turbo covers. The nuts with springs are really tight. Remove the 3x 13mm exhaust nuts. Remove 4x 13mm nuts from the exhaust manifold. Remove the actuator. The turbo is now ready to remove from above, taking the exhaust side first.
Process took an entire day with help from an assistant to help from either above or below to guide the tools through the minute gaps.
Really difficult job!!!
Old Sep 24, 2013 | 12:03 PM
lehannon's Avatar
Sorry to just butt in but I can't figure out how to get started. I want to list my Volvo for sale. I've seen reply buttons on individual posts but haven't seen post new thread buttons. What am I missing? Thanks Larry
