XC70 Torque Converter Shudder
Old Apr 29, 2021 | 05:11 AM
Lucky Pete's Avatar
Default XC70 Torque Converter Shudder
I have a lovely 2006 XC70 in great condition. Transmission is a Aisin TF-80sc. I am experiencing what I am told is most likely shudder due to bad TC lock-up.
This shudder happens at around 1700 1800 rpm at 22 mph and 40 mph.
No codes have been found and gear changes are fine.
What I don't understand is when the shudder occurs, if I hold that RPM the shudder continues for however long I wait. If I increase OR decrease the RPM say up to 2000 or 1600 the shudder stops instantly. If I hold the RPM while its shuddering there is no visible flutter of the tachometer. My question is 4 parts. (1) If its TC lock-up slip why would a slight increase in RPM stop it and not just make it worse?
(2) If it is TC lock-up could an ATF drain (replace) fix it?
(3) If it is slipping would I expect to see some sort of fault code stored?
(4) Any ideas on other possibilities?
All or any help would be gratefully received.
Lucky Pete (or maybe not)
SLT16
Feb 25, 2020 06:07 PM
Moetheshmoe
Jan 13, 2019 03:27 PM
pvc70owner
Sep 29, 2018 08:44 PM
carlosr23
2001-2013 model year XC70
Jun 11, 2017 11:52 AM
yyk
Feb 4, 2013 03:58 PM
