Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Stock boost on my car?
Old Dec 16, 2007 | 12:35 AM
Volvo V70R's Avatar
Default Stock boost on my car?
What is the stock boost (in PSi) im getting on my 2000 V70R awd? Is there a way (such as a boost controller) to get more out of it? What can my otherwise stock internals handle?
...also, anyone got a good spot for a boost gauge in this thing? lol
Old Dec 16, 2007 | 04:05 PM
Volvo V70R's Avatar
Default RE: Stock boost on my car?
Anyone?
Old Dec 16, 2007 | 08:18 PM
Usually about 8 to 10 PSI.
Old Dec 16, 2007 | 08:51 PM
Volvo V70R's Avatar
Will a boost controller improve things? Make a little more pressure that is? Could my stock internals handle it?
Old Dec 16, 2007 | 10:08 PM
I wouldn't really go over 10.
It should handle up to 15 but I really wouldn't go past 10 or 12.
Old Dec 16, 2007 | 10:33 PM
Volvo V70R's Avatar
So I couldnt very well push 12 with my stock one? THanks for all the help BTW.
Old Dec 16, 2007 | 10:59 PM
S70driver's Avatar
1. Supposedly 1999+ Volvo use ME7 and ME7 doesn't like MBC's. So you can try it, but the car might not like it.
2. Your internals should be able to handle 15-17 PSI fine. I wouldn't go above that. See your an "R" HPT (High Pressure Turbo) and you have a bigger turbo that can handle more pressure unlike the LPT (Low Pressure Turbo). See on the LPT 15PSI is about the max you want to run because after that the tiny turbo is out of its effeciency range. With the HPT you should be able to run 15PSI all day long with no problems. However I agree with TECH and, that 12PSI is a good number to stick around.
Old Dec 16, 2007 | 11:43 PM
Volvo V70R's Avatar
I see, than how can I get my current turbo to push around 12?
Old Dec 17, 2007 | 08:09 AM
S70driver's Avatar
ORIGINAL: Volvo V70R
ECU upgrade.
Old Jan 15, 2008 | 02:12 PM
y2kv70r's Avatar
You are already at 12psi. That is stock boost on the '00 R. You will see it vary some on a gauge, since the factory BCS likes to be stingy with the pressure. You can safely run up to about 20psi on stock internals, as the '00 has the larger (2.4, not 2.3) engine, and stronger bottom end. I have even heard of people exceeding 20psi, but I'm not sure I would risk it. Most chips will take you to the 17-20psi range, and 290-320hp with no other mods. You CAN run more boost, but it takes some ME7 trickery, and although it feels faster, my 1/4 times dropped about .1 running 3 psi more boost, so your best bet really is an ecu. Check RICA, BSR, IPD, and Speedtuning USA
Old Jan 16, 2008 | 10:56 PM
BuildinAs70's Avatar
lol, just pinch off your wastegate line.
dabossk
Oct 11, 2011 04:13 PM
03S60
Jun 8, 2011 04:27 PM
endneu913
Mar 28, 2010 11:41 PM
alphaville
Jun 1, 2009 10:20 PM
olegs70glt
Jun 15, 2007 01:36 PM
