Silicone hose for 850, V70, S70, C70. 94-2001 Group Buy
I have access to a supplier that can make silicone radiator and overflow tank hoses for (type1) Turbo 94-97 850, (type 1) Turbo 98 S70, V70, C70, and (type 2) Turbo 99-01 S70, V70, C70. If you look into the silicone hose, you'd know every few people make overflow tank hoses. These hoses are for turbo cars only. Hose is 3 ply, may require you to use bigger hose clamp because of the thickness of the hoses.
Type 1 replaces
94-97 Turbo 850 sedan and wagon.
98 Turbo C70, V70, S70
Expansion Tank Hose
9135267
Expansion Tank Hose
6842894
Upper radiator hose
1335433
Lower radiator hose
3507930, 9470409
Type 2 replaces
99-2001 C70, S70, and V70.
Expansion Tank Hose
9445378
Expansion Tank Hose
9470676
Upper radiator hose
1335433
Lower radiator hose
3507930, 9470409
I have a type 1 kit on my Turbo 850. I had to shorten the hose from thermostat to expansion tank, all the other hoses fit great.
Currently looking at $120 shipped for each kit. Turn around time is about 2 months. Looking to start at the end of March. Please send PM if interested.
Color choices are black, blue, red, and purple. Each set will come with 4 hoses, depends on the type you want.
FAQ
1. I heard heard silicone hose can cause to you lose a small amount of water over a long time period?
Yes, water permeation is more with silicone hose. The main benefits of silicone hose are that silicone hose is oil resistant, also can withstand higher temperature, and being 3 ply, it is also much tougher than the 1 ply factory hose.
2. Is there a 2 hose kit for overflow tank for sale?
No, not at this time. This kit is only for 4 hose kit.
3. Are these actual Samco hose?
No, these are manufactured in China, Samco hose are manufactured in UK. I'm not sure why the factory decided to put Samco name on their hose instead of their own name as these are high quality hose from what I can see, otherwise, I wouldn't have a set on my own car.
Type 1 replaces
Expansion Tank Hose
9135267
Expansion Tank Hose
6842894
Upper radiator hose
1335433
Lower radiator hose
3507930, 9470409
Type 2 replaces
Expansion Tank Hose
9445378
Expansion Tank Hose
9470676
Upper radiator hose
1335433
Lower radiator hose
3507930, 9470409
FAQ
Chrispy_T
Feb 18, 2014 11:37 PM
fcpgroton
Jan 10, 2013 07:24 PM
