Penta Discuss Volvo Penta Marine Machines Within.
Volvo Penta AQ151 carb question
Old Jul 26, 2012 | 09:32 PM
Da Tow'd's Avatar
Default Volvo Penta AQ151 carb question
Howdy gang,
2.3L 4 cylinder sohc Volvo penta engine twin Solex downdraught carbs
Anybody here happen to know if the two brass plugs on the intake manifold under each carb can to be used as a vacuum port.
Looking down into the rear carb it doesn't seem to have the gas flowing when running like the front one. low power
it has new carb kits with pumps
I'd like to install a vacuum gauge.
I've been told you can balance them using the vacuum.
I have a unisync and a snap on vacuum balancing tool--it is a clear plastic cylinder with a red sliding piston inside and a vacuum hose on each side - The carbs are balanced when the red piston is in the middle.
I was wondering if I could adapt the two brass plugs port to each side of the tool
thanks
hank
syncro system
Aug 1, 2009 05:54 AM
760turbo
Penta
Oct 24, 2008 10:32 PM
richdom
Penta
Jun 11, 2007 12:29 PM
martinbowe
Jul 16, 2006 04:09 AM
islander
Penta
Jun 3, 2006 06:41 PM
