Sights N Sounds Post all of your video and sound clips here.
Audio Speakers
Old Jul 25, 2019 | 08:33 AM
MM2's Avatar
MM2
Default Audio Speakers
This morning my audio speakers sounded fuzzy, no matter what I played on the system. My vehicle is new 2019, I have owned it since May. The speakers worked fine yesterday and sounded terrible this morning when I turned it on. Any ideas?
Old Jul 25, 2019 | 08:42 AM
play with the fader and balance. if it sounds fuzzy on all corners, then you know its not the speakers. Does it sound the same regardless of source ie fuzzy on FM, CD, MP3/bluetooth? If its only on radio, then its possible the antenna/signal amp is acting up. Does the sound change with engine speed (ie a bad ground can let RF in). Depending on these variables, it will either point to the antenna, power amp or the head unit (preamp/tuner) or once of the source components. Given your car is new, sounds like some warranty work.
Old Jul 25, 2019 | 09:04 AM
MM2's Avatar
MM2
mt6127, thank you. I will try your suggestions today. I know, the fact that it is so new I didn't think I should have such issues, but will keep the warranty in mind as well
shirley
Jul 29, 2016 08:31 PM
Vegals
Feb 28, 2015 12:25 PM
qc24
Jun 14, 2011 03:49 PM
Volvo240T
Jun 16, 2005 02:32 PM
yng740gledriver
Oct 17, 2003 05:10 AM
