Sights N Sounds Post all of your video and sound clips here.
Fog light help
Old May 19, 2017 | 11:07 AM
HARRINGT0N's Avatar
Default Fog light help
I just purchased a 2005 V70. There is a button on the dash to apparently turn on rear fog light but it does not have front fog lights. I wanted to throw some after-market fogs on the front of the car and wire them to the button for the rear. Is this possible to do?
Thanks
Old May 19, 2017 | 12:17 PM
Smith Volvo's Avatar
Banned
Thanks
I would not do this because the fog lamps are controlled by your CEM and REM and I believe would cause issues. I would recommend the factory kit #30744346 and wire harness #8622840. Would still need a software download also.
Old May 19, 2017 | 01:32 PM
HARRINGT0N's Avatar
i need a software update just to add some lights? That's crazy. I'm guessing the dealer needs to do this.
Old May 20, 2017 | 07:30 AM
ES6T's Avatar
If you want to do it the right way, yes. And yes, the dealer does the software.
You can try your method but the CEM/REM might detect a higher than usual draw and shut the circuit down. You would have better luck adding a circuit direct from battery voltage and using a generic switch installed somewhere.
Old May 20, 2017 | 03:53 PM
HARRINGT0N's Avatar
okay so at least I can do it my own way with a wiring harness and switch running off battery. Thanks for the reply
Benjamin Ixcot
Oct 23, 2017 06:49 PM
metalslug
Sep 18, 2010 07:27 PM
MyS60T2.42Slow
Nov 9, 2006 09:14 PM
mike322
Jan 9, 2006 07:59 PM
