01 V40 Strut Assembly Question
Anyone know how I can remove the springs from the strut on a 2001 V40? I have the spring compression tool, but I still can't seem to get the nut off the strut assembly....any suggestions? Thanks in advance.
RE: 01 V40 Strut Assembly Question
Are you using an Impact gun?
If not then that would be the easiest. If not you will have to make a special tool to hold the center while you turn the nut. |
