Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and talk about it here.
01 V40 Strut Assembly Question
Old Sep 27, 2006 | 03:04 AM
NYSpeedRacer's Avatar
Default 01 V40 Strut Assembly Question
Anyone know how I can remove the springs from the strut on a 2001 V40? I have the spring compression tool, but I still can't seem to get the nut off the strut assembly....any suggestions? Thanks in advance.
Old Sep 27, 2006 | 08:39 PM
Default RE: 01 V40 Strut Assembly Question
Are you using an Impact gun?
If not then that would be the easiest.
If not you will have to make a special tool to hold the center while you turn the nut.
rupenzelleo
Jul 27, 2015 07:36 AM
rupenzelleo
Feb 24, 2015 07:09 AM
ldutton6
Jan 14, 2015 08:56 PM
v70 2.4t
Aug 10, 2008 05:54 PM
daver80
Jan 16, 2008 07:36 PM
