'01 V70 105k Suspension/Steering Diagnosis
So I know I will need new struts, the old ones are shot. Looking at options for OEM-like ride quality.
I recently hit a large pothole (yay Chicago) and now that threw a wrench in everything (on top of my radiator fan exploding and damaging the radiator) I know my rims are bent, but I'm trying to figure out if I will need to replace; ball joint, inner and/or outer tie rods. Alignment is off, and there is a vibration/pull on the steering wheel, I'm assuming the vibration/pull will go away after replacing the damaged rim. Also it handles oddly on that same side when turning hard. Almost like it pulls and then hesitates, IDK that's the best way I can describe it ATM. |
