Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and talk about it here.
'01 V70 105k Suspension/Steering Diagnosis
Old Jan 3, 2017 | 05:17 PM
filofthefuture's Avatar
Default '01 V70 105k Suspension/Steering Diagnosis
So I know I will need new struts, the old ones are shot. Looking at options for OEM-like ride quality.
I recently hit a large pothole (yay Chicago) and now that threw a wrench in everything (on top of my radiator fan exploding and damaging the radiator) I know my rims are bent, but I'm trying to figure out if I will need to replace; ball joint, inner and/or outer tie rods. Alignment is off, and there is a vibration/pull on the steering wheel, I'm assuming the vibration/pull will go away after replacing the damaged rim. Also it handles oddly on that same side
when turning hard. Almost like it pulls and then hesitates, IDK that's the best way I can describe it ATM.
rodmodder
Nov 5, 2009 06:17 PM
nhpokey
Oct 1, 2009 05:05 PM
kriflic
Aug 11, 2009 12:57 PM
S80Mama
Jan 21, 2009 09:25 PM
s80t6schcik
Mar 12, 2007 08:31 PM
