11v at the headlights
Old May 20, 2018 | 08:43 PM
leohtbaere's Avatar
Default 11v at the headlights
I'm in the middle of repairing my 240's headlights and I'm finding that I'm getting about 11 volts at the headlight connectors. Is this normal or does the ~1v drop suggest something is wrong?
Old May 20, 2018 | 10:16 PM
jagtoes's Avatar
Check your grounds. You should be getting better the 12v.
Old May 21, 2018 | 12:04 AM
is that 11V with the headlights plugged in and shining, or 11v when the lamp is disconnected so you're just reading the voltage at 0 amps ?
Old May 21, 2018 | 06:08 AM
leohtbaere's Avatar
That's 11V only when shining on both the high and low beam setting. Otherwise it drops to 0.
tarnab
Dec 17, 2014 03:51 AM
VDriver24093
Feb 21, 2011 04:35 PM
keyfoo
Aug 24, 2004 12:26 AM
acldrwd
Oct 14, 2003 09:25 AM
