Man looking soooo good!!!
4 Attachment(s)
Thanks tech.
Got a 205/50 16 to test also. here is the 205/50 up front and the 225/50 in the back. Attachment 20501 Attachment 20502 with the 1" spacer in the rear, the fender is on the tire with the 225. the 205 is fine. but both will require fender work in the rear to work. The front is gonna be 205/50 for sure. the backs will also be 205/50 for rotational purposes and it will look better balanced front to rear. 205/50 front: Attachment 20503 205/50 rear: Attachment 20504 |
I kind of like that look on it.
Looking good. We need to get a meet together once it's done!
Originally Posted by washdup
(Post 240671)
for sure! it has been a while since I have been to one. |
4 Attachment(s)
Tires will get ordered this week. Going to be trying the Continental ExtremeContact DW 205/50 16. Should be a nice light(19lbs) street/ middle track tire.
After some carefull thinking... The 8" springs are back in the rear. I found that Eibach sells a 3.6" ID helper springs which will fit perfectly on the lower rear perch. I only have to make a custom adapter to mate the 3.6" ID helper spring to the 5" OD spring. Luckly, the 5" OD springs have and ID of 3.96" so, this wont be too hard to make... If The adapter is not possible, then I am stuck with the 11" springs. Here is the current set up. all These pics have the 1" spacer on the rear.: Attachment 20470 http://i426.photobucket.com/albums/p...A251192_cr.jpg Finally rolled the rear fenders, had to modify the tool, by drilling another hole for the pivot arm to get full push on the fenders: Attachment 20471 Attachment 20472 on bumstop: Attachment 20473 no rubbing with these rims pushed this far out. i can easily stuff a 255 in the rear now with the right rim and offset. The 1inch spacers in the rear are still not large enought to match the front track, but the rear track is close, and looks sooo much better now. Front track is 56.3" and the rear track is 53.5" on a stock 240. Now I have 56.3" front and 55.5" rear. |
Looks good!
THanks man!
I think the 244 looks great just as it is now, don't touch it! Perhaps a light window tint in the future, but a great looking car is one where the owner realises they've done just enough.
Spray some rust preventative up behind those rolled guard lips, they'll trap dirt and water now, so give them all the help they can get Regards, Andrew. |
Thanks Andrew. Agreed, a slight tint and that will be the it for the outside.
10 Attachment(s)
new tires are here and on the car.
Attachment 20445 Attachment 20446 Lowered the front down 2 turns, which is ~3/8". Attachment 20447 Attachment 20448 http://i426.photobucket.com/albums/p...A301234_cr.jpg Here is the final ride height (bad images). Attachment 20449 Attachment 20450 Attachment 20451 Attachment 20452 Attachment 20453 Attachment 20454 Hopefully these tires have good tread life. Anyways... Measured the upper spring seat in the rear, and now a new one can be made to accept the 3.63 ID helper springs. Also, gonna have to slot the lower arm and upper plate holes ~.19" to stop the rubbing from the springs pushing to the rear from the up and down motion. |
Everyone seems to love the Conti DW's (and their all-season siblings, the DWS's). They also have a 60-day unconditional guaranty, so if you don't like them, or if the sizing isn't right, you can swap them for something else.
7 Attachment(s)
Got the helpers in, and test fitted them with some homemade adapters/seats.
Attachment 20415 Attachment 20416 Attachment 20417 Attachment 20418 The helper springs is actually compressed ~3" when the shocks are in at full droop. perfect. Attachment 20419 Attachment 20420 Finally put the skid plate on: Attachment 20421 |
I never heard of rolling fenders? What does it do and how do you do it?
Thre is a 2" lip of metal on the wheel well. This lip interfers with the tires when you lower the car are push out the rims and or get fatter tires. By Rolling the fender, you push that 2" metal lip up into the wheel well which allows the tires to move up and down without hitting the lip. You can see the before and after images above.
That thing is LOW!!! Looks Awesome!
4 Attachment(s)
thanks tech.
Got the spring adapters and seats done for the rear. Machined from T6 Aluminum. Going to drop them off at the anodizer this week. Attachment 20357 Attachment 20358 Attachment 20359 Attachment 20360 |
Pure beauty there!!!!!
Thanks man! black anodizing to finish them off and the car will be driving.
It is the last three weeks of this semster and it is crazy. car hasen't been touched since last post. |
You did an awesome job with the car. Enjoy driving it!
