1984 244; overdrive will not engage
Old Feb 18, 2008 | 05:27 PM
mattfoley's Avatar
Default 1984 244; overdrive will not engage
I have a 1984 volvo 244 sedan. The "OD Off" light is illuminated on the dash and the car will not shift into overdrive. What is causing this problem? Switch? Transmissions problem? I am considering installing the solenoid bypass kit, but am not sure it will cure the problem. Thoughts or suggestions? Thanks.
Old Feb 18, 2008 | 06:15 PM
Default RE: 1984 244; overdrive will not engage
Can you turn the light on and off with the switch?
If not then I would look at the relay first.
Old Feb 18, 2008 | 06:31 PM
mattfoley's Avatar
I was hoping I would hear from you, TECH.
No, the light does not go on and off...it stays on.
Where is the overdrive relay located?
Old Feb 18, 2008 | 06:35 PM
It is a pain to get to you need to remove the glovebox.
Then it will be behind the center vents. It is a white relay that is pretty long.
Sometimes you might be able to resolder it and it might work.
lilsilver85
Aug 29, 2014 04:07 AM
rickisnotserious
Sep 26, 2013 09:17 AM
Spyros
Jun 13, 2012 04:24 PM
Spyros
May 27, 2012 07:15 PM
Rowsdower98
Feb 28, 2009 05:47 PM
