1984 Volvo 240 DL Transmission ID
I need to top off my transmission fluid but my manual is packed away because of a move. I checked the online manual and it lists the following fluids are used:
BW55 Automatic Transmission Fluid type G(FLM) AW71 Automatic Transmission Fluid type Dexron II D How do I know whether I have a BW55 or AW71 transmission? Thanks! |
The BW is 3 speed, the AW is 3 +OD, with an Overdrive button. If you post a picture it'll help. But if you don't have the OD, it's a BW. Most likely you have the AW; I believe the BW was not used as late as 1984.
Originally Posted by lev
(Post 474025)
