1984 Volvo 240 DL Transmission ID
Old May 29, 2019 | 02:57 PM
isbjorn's Avatar
Default 1984 Volvo 240 DL Transmission ID
I need to top off my transmission fluid but my manual is packed away because of a move. I checked the online manual and it lists the following fluids are used:
BW55 Automatic Transmission Fluid type G(FLM)
AW71 Automatic Transmission Fluid type Dexron II D
How do I know whether I have a BW55 or AW71 transmission? Thanks!
Old May 29, 2019 | 04:21 PM
lev's Avatar
lev
The BW is 3 speed, the AW is 3 +OD, with an Overdrive button. If you post a picture it'll help. But if you don't have the OD, it's a BW. Most likely you have the AW; I believe the BW was not used as late as 1984.
Old May 29, 2019 | 04:31 PM
isbjorn's Avatar
Thanks for the reply! I could post a picture, but I definitely have Overdrive so it looks as if I have the AW. That was a great help.
lilsilver85
Aug 29, 2014 04:07 AM
Ulli
Oct 8, 2012 01:30 PM
mkasperbauer
Apr 22, 2012 09:06 PM
lala240
Jul 25, 2010 05:58 AM
mike86dl
Jun 27, 2010 05:37 PM
