1984 Volvo DL headlight help
Old Aug 8, 2012 | 11:43 AM
jdm79's Avatar
Default 1984 Volvo DL headlight help
Hi-
I was in a small accident over the weekend and my driver's side headlight and turn signal got damaged. I need help figuring out how to replace the mount for the headlights. The bulbs work when I turn on high beams but not on low beam. I've attached pictures. If anyone knows how to fix the mounts and what parts I will need, that would be incredibly helpful. Thanks.
Attached Thumbnails 1984 Volvo DL headlight help-photo.jpg   1984 Volvo DL headlight help-photo1.jpg
Old Aug 8, 2012 | 10:11 PM
swiftjustice44's Avatar
Well, you're there...You will have a much better idea what parts will be needed than we. .Three phillips screws hold on the turn signal lens...remove it and see if the "bucket" itself is damaged. It to removes quite easily. Remove the silver trim of the headlamps. If you're not sure, examine the passenger side that is undamaged and see how it comes apart. Just keep removing broken parts until you get to unbroken, unbent parts. The damage looks extremely simple to fix BTW.
Old Aug 8, 2012 | 10:26 PM
if you go deep enough, it will look like this, only unbent (this picture is prior to some minor body work). the headlight assembly is attached to a plastic adjuster plate which bolts onto the metal body parts as seen here...
the adjuster plates are attached via 3-4 nuts on posts from the back.
the turn signals are also screwed onto those adjuster plates.
Old Aug 10, 2012 | 09:07 AM
jdm79's Avatar
Thank you for the help. Seems like a very doable job.
Jason Johnson
Jun 14, 2014 11:15 AM
kidcudi
Jun 10, 2009 11:10 PM
Rowsdower98
Feb 28, 2009 05:47 PM
christophicer
Nov 13, 2008 07:07 PM
Leovv
Mar 17, 2003 08:45 PM
