Heated Oxygen sesnor(lean mixture/part throttle) 94-up.
Old Aug 9, 2012 | 09:10 AM
masterpilot321's Avatar
Default Heated Oxygen sesnor(lean mixture/part throttle) 94-up.
What does this code mean on my 1991 volvo 240
Heated Oxygen sesnor(lean mixture/part throttle) 94-up. (231)
Old Aug 9, 2012 | 10:31 AM
nuclearseal's Avatar
Please keep in mind I am far from an expert.
But I had the 2-3-1 code on my 1993 240 and it was the oxygen sensor, replaced it, no more code.
Old Aug 9, 2012 | 11:54 AM
I had previously replaced it and the sensor that i had was brand new. Do you know if it is possible that it is an ignition problem?
Old Aug 9, 2012 | 12:45 PM
I don't think ignition, that code has to do with the "lamda" I believe, fuel/air mix.
I got my 240 at an auction and it sat for a year before I go it, I got that 2-3-1 and couple others. Check for vacuum leaks (that was my other problem, besides a fuel pump).
Old Aug 9, 2012 | 01:30 PM
that error can be a lot of things, including air leaks in the intake plumbing, flakey or marginal MAF (or dirty connections on the MAF), tired O2 sensor, vacuum leaks, funky ECT thats making the car think the engine is at the wrong temperature, etc. if you clear the error, does it come right back?
Old Aug 9, 2012 | 06:56 PM
I have not tried to clear it yet but your right that it is a good thing to check first.
Thanks for the input
Old Aug 10, 2012 | 12:52 PM
swiftjustice44's Avatar
Also, an exhaust leak at the manifold will cause a lean code. Air is sucked in at the leak and when it passes by the O2, tricks the O2 into thinking it's lean. It will then report to the ecu and the ecu will richen the mixture more than ideal. Running rich will kill both your mileage as well as your catalytic converter. If the code doesn't come back, then it was just a tired O2.
Old Aug 10, 2012 | 06:05 PM
I reset the check engine light and it came right back on so that rules out the O2 sensor and i just got it inspected 2 weeks ago so i don't think that it is a manifold leak (correct me if i am wrong because i am new to car mechanics), but i have yet to check for a vacuum leak.
Enzo cat
Feb 25, 2011 03:00 PM
bigrb247
Dec 19, 2009 05:00 PM
dman777
Jul 22, 2009 09:40 PM
elchingon2002
Mar 11, 2008 10:41 AM
