1986 Manual Swap Question
Old Nov 6, 2020 | 03:51 PM
whatdidigetmyselfinto's Avatar
Default 1986 Manual Swap Question
Hello, I am beginning the process of swapping my 1986 245 automatic to a 1989 5 speed manual transmission. Before I begin, I want to make sure I have everything in order. Do I need a new ECU for this transmission?
Thank you!
Old Nov 6, 2020 | 05:40 PM
Originally Posted by whatdidigetmyselfinto
1989 5 speed manual transmission. Do I need a new ECU for this transmission?
NO. The ECU will be ok. And cars that old did not have any electronics for transmissions. (other than OD relay with later 4 speed auto cars or 4+od cars) I did that years ago on a 1976 - and was very pleased with the outcome - Replacing a 3 speed auto with a 5 speed (mine was 4 +od) was well worth the time and effort. Even with the trouble of putting in a clutch pedal.
Old Nov 6, 2020 | 06:07 PM
ok great thank you! I have also been told that I am needing a matching crank sensor for the transmission. Is this something immediately necessary? If so, any recommendations on where to purchase?
Old Nov 6, 2020 | 06:21 PM
the crank sensor is needed for a 1989+ engine
your 1986 engine uses a hall sensor in the distributor.
what you WILL need is the 3-pedal assembly from under the dash of the manual car, I forget if that's a cable or hydraulic clutch on a 1989, but if its a hydraulic clutch, you'll need the clutch master cylinder from the donor car.
you'll need the manual drive shaft as its got a different end and is a different length than an automatic drive shaft. I'd plan on using a new flex disk, and new shaft support bearing and carrier bushing.
And of course, the shift linkage, the transmission itself, and the transmission mounting crossbar. I'd plan on using a new clutch and new throwout bearing.
oh, you'll need to swap the 'flexdisk' on your 86's engine for the flywheel from the manual car's engine.
BigBertha
2001-2013 model year V70
Mar 31, 2017 02:07 PM
zdean
Mar 30, 2015 09:16 AM
S70LE
May 25, 2010 08:28 PM
98_S70_T5_Driver
Oct 28, 2009 05:52 PM
unpimptheride
Dec 25, 2006 01:26 AM
