1989 volvo 240 NO START Grrrrrr!
Old Mar 24, 2008 | 08:11 PM
zambonni's Avatar
Default 1989 volvo 240 NO START Grrrrrr!
Hey, my 89 240DL will not start.
It cranks but will not catch. I bought a new battery and replacedEVERY fuse. I checked the Fuel Pump relay. It clicks when i turn the ignition switch to ON. I even went to the junk yard and got a spare. I replaced all the plugs. I checked spark from each plug and it was good. I check spark from the coil and it was good. I pulled the cover off the timing belt to see if the belt was broken. The timing belt was fine. I jumped the the Fuel pump at the Relay connector and it worked.
The wierd thing is........ I pulled the fuel line off just before the rail and stuck the end into an empty 2 liter bottle. When i jumped the fuel pump it pumped just fine and filled that whole bottle in about5 seconds. But when i put the relay back and tried to start it, NO fuel was being pumped into the 2 liter bottle. Isnt the fuel pump supposed to pump fuel during startup????
ANY SUGGESTIONS??? I am so frustrated.
Thanks
-John
Also, no Diagnostic codes present either.
Old Mar 25, 2008 | 03:35 AM
jonnyboyca's Avatar
Default RE: 1989 volvo 240 NO START Grrrrrr!
use the Search on here for 'fuel pump'.. there's a lot of posts about it.. i'm sure you'll find some answers. good luck!
~jon
Old Apr 1, 2008 | 04:54 PM
zambonni's Avatar
Hey guys. I got it working! I pulled the wiring schematic and got out my highlighter. I narrowed it down to the relay. It would not get power to the fuel pump. SO, i jumped the YELLOW/ORANGE wire to the RED wire, WITH the fuel pump relay still connected. When i did that, it started right up. If you need any more details please email me at zambonni@aol.com. Thanks!
Also, I want to praise the Lord for allowing me to fix this.
VOLVORRD
Sep 30, 2014 11:02 PM
steelheaddan
Feb 11, 2013 11:52 PM
alpine
Aug 12, 2010 04:04 PM
mweav
Dec 10, 2007 12:49 PM
vwdodge
Mar 2, 2005 06:45 PM
