1987 740 GLE B230F coil resistor?
Old Mar 29, 2008 | 11:32 PM
bricksRfun's Avatar
Default 1987 740 GLE B230F coil resistor?
1987 740 GLE B230F cranks great but will not start. Currentlyreplacing the coil and there is a part connected to the coil I haven't been able to identify. Would like to know aboutthe small black box,about 1"x1"x1.5", mounted on coil bracket,connectedbyone wire to the coil. Thislittle black box is connected to the + side of the coil on the lead next tothe blue wire and ared and white wire is connected to - side of coil.
Is the little black boxa resistor? Can it be tested? Is a replacement part available? Isit required in order for coil to work and make car start?Thanks very much for any help.
Old Apr 1, 2008 | 05:48 PM
bricksRfun's Avatar
Default RE: 1987 740 GLE B230F coil resistor?
Well, my coil replacement worked and thecar runs great again. I'm still curious about thelittle black boxabout 1"x1"x1.5", connected to the + side of the coil. I can't find that part described inHaynes manual or auto parts stores. If I disconnect it (permanently) from the coil, does anyone know if that wouldcause problems? Thanks very much for any help.
JEFFH
Jul 30, 2015 10:07 AM
mdmach
Feb 24, 2013 06:20 AM
jakebob
Feb 28, 2010 05:26 AM
iann3
Nov 1, 2008 02:28 PM
core
Aug 19, 2008 11:07 PM
