1990 240 taillight/brake lights
A few days ago I noticed the brake light in the rear window was on when I turned on the headlights/taillights. When I stepped on the brake pedal, the rear window brake light came on a bit brighter. I could also see reflected against the garage door that the left and right brake lights were also on with headlights/taillights and that they too became a bit brighter when I stepped on the brake pedal. A few days later, lighting returned to normal except the left taillights would not illuminate when I turned lights on. However, brake lights worked normally, as did reverse and turn signal. Light bulbs are all OK. With the light switch set to parking lights, I tried resetting the plug into the left rear light assembly and noticed that the brake lights again illuminated at one point, including rear window brake light. When fully reset, left taillights went out but brake, reverse, and turn lights all resumed normal operation. Any ideas?
I searched as best I could through other threads, couldn't find this problem... if I missed it, please point me in the right direction.
I'm no expert at electrical issues here but I would say it sounds like a short in the left tailight circuit or maybe corroded socket. My 81 is alot older and might be different but I noticed the taillight assemblies have an exposed circuit anything touching it thats metalic or conductive could contribute to the problem.
First remove the negative batt terminal
Remove each of the bulb holders one at a time and clean bulb holder and circuit board contacts.
After you have all the bulb holders clean and reinstalled,unplug the harness on the circuit boards,clean the contacts on the circuit boards and the wiring connector,and reinstall.
Next follow the wire that is attached to the circuit board(see pic)follow it to the grounding point,remove and clean,reinstall,this should take care of the problem.
Dan
Dan
Sort of... problem is the plugs have worked loose over the years. i'm sure cleaning the contacts helped... haven't quite solved how to consistently keep good contact all the time. looked to tighten it with a c-clamp or band of some sort but couldn't figure out how to make it work. Lights work fine right now... but something will bump the connection a bit loose I'm sure in the next day or 3. Age and stage of the car... it's only 20 years old with 190k + miles... things just loosen up, I think.
Thanks for checking back... I forgot to log back in and report out.
sounds like a short in the wiring
My '93 240 had similar issues with the tail lights. I had various problems with lights not working. I found that the ground wire in the hinge was causing most of the issues. Once I took off the hinge and replaced the ground (I just crimped a new wire to it) everything started working. I also replaced the wires through the hinge (the window brake light, wiper, and heated window).
Anyway, I bet your problem has to do with the wires going through the hinge.
The broken ground wire even caused my window brake light to stay on while the brake was disengaged and once I engaged the brake it would turn off. Once I fixed the ground everything was back to normal.
I have a sedan, no hinge. The loose connection I experience is the piece that connects to the circuit card. The original problem was caused by the plug being slightly cocked, not on straight... now I have the plug on straight, but the plastic tab holding the plug in tight has loosened over the years, so it's not always completely snug.
you need new ciruit board paper....or if it is just the plug you can go to a junk yard cut the plug and then butt connect it into yours...you do not want to have to do a wire harness...PITA!!
liweih21
05-28-2014 05:08 PM
ivrylineslead
09-15-2006 08:45 AM
